Skip to main content
Documentation Index
Fetch the complete documentation index at: https://docs.ghost.org/llms.txt
Use this file to discover all available pages before exploring further.
Error
Open developer tools to check for errors in the JavaScript code: TypeError: n.item is not a function or Uncaught SyntaxError: Unexpected string
To fix
It is recommended that you add a page rule which turns off some RocketLoader, mirage2 and autominify for the path /ghost*, so these features don’t affect the Ghost admin panel.
This solution is for developers who are maintaining a self-hosted instance of Ghost. If you’re on Ghost(Pro) both nginx and Cloudflare are configured as standard and you don’t need to do anything.
