Documentation Index
Fetch the complete documentation index at: https://docs.ghost.org/llms.txt
Use this file to discover all available pages before exploring further.
Production install
Ifnvm is installed locally in /root or /home then you’ll run into permission problems. Ghost requires a system wide installation. We recommend uninstalling nvm to avoid permission problems. A symlink from the local installation to usr/bin/node will not work.
Uninstall nvm using:
~/.bash_profile or ~/.bashrc and remove any nvm lines.
Local installation
If you run into problems during a local install, it could be due to your installation ofnvm (Node Version Manager).
Ensure nvm is installed correctly:
- Ensure that
nvmis not installed in the root folder/root/.nvm. If nvm is installed in the root folder, uninstall nvm, and reinstall it using a non-root user. - Set your
nvmdefault version to the one you will use for Ghost before installingghost-cli. If your default is different, you should switch to the correct version each time you start a new session and run any ghost commands. - Ensure ghost-cli is installed in the correct environment. On a machine with nvm configured correctly, you should see:
ghost-cli in a different environment than the active node environment. ghost-cli needs to be installed and run in the same environment.
To resolve this choose one of the following:
Run npm install ghost-cli -g in the current environment to get the right sqlite3 node module into the environment and go through ghost setup process again.
If you remember which nvm node environment you’ve installed ghost-cli under, run nvm use <node version>.
